Hi all
My first post.. as I am freeezing
Combi boiler (Vokera Linea) - hot water fine
Cannot get radiators to heat. Although pipe from boiler does heat slightly. Sorry i am not too technical !! Anyway, have bled all radiators, and switched on full (so that boiler thermostat is set to full and on all the time).
A few months ago thermostat was disconnected just by disconnecting wires at boiler as the wall it was mounted on was getting knocked down. Could it be to do with this? do you have to do somethin else when disconnecting a thermostat so that the firing up of the heating is overridden so that the boiler knows it is no longer communicating with a thermostat?
or will it be the pump or a valve do you think?
thanks for any help.
i did see another post on here which suggested it could be a valve that has got stuck, but it wasnt for a combi boiler so i am not sure
