Can't find the leak
6 Nov 2011
Hertfordshire
I have a constantly dropping pressure dial on my boiler (Potterton Performa 24 Eco HE) and I cannot find the source of the leak.
It had a slow leak for quite a long time but now it drops from 1.5 to 0 in 2-3 days.
I had the PRV changed but that hasn't fixed the issue.
There's never been any sign of water on ceilings, floors or walls but it could be on the ground floor somewhere (I have lifted boards and don't expect there's a dodgy pipe).
The heating engineer has said it's probably the heat exchanger but I've been quoted quite a lot to fix it so hoping I can establish its definitely that to blame.
Anyway I can test it?
pressurise your boiler, turn it off at the main switch and then turn off the flow and return valves under the boiler, (leave for 24hrs) if the pressure stays the same its not the boiler heat ex.
Dan-Robinson - the YTUBE uploader clearly stated ,
"...I was called to repair this Potterton Perfoma 24 boiler because it was not performing at all !. No wander the other Corgi engineer has taken the PCB ( printed circuit board) with him. During investigation, a leaking diverter valve is found. If left not repaired this boiler may develop other faults. Electrical failure due to water ingress, boiler go to low pressure, no hot water but heating ok, are just 3 possibilities and guess what there are more.... ............Contact us to get it repaired.!"
JamesWren wanted to know how to spot a leak on his Potterton Performa 24 Eco HE, and I suggested he look at what someone else found, hence the sodding video! :P
So there! Nah** nah** :P
if you cant find it anywhere obvious and dont want to lift your floorboards and have a look then you could try this...
http://data:image/jpeg;base64,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 http://data:image/jpeg;base64,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
844300_R_Z001
but try and what Picasso suggested first to eliminate the heat exchanger
Hi and thanks for replying.
The boiler is in a tenanted property so it's difficult to leave it off for long.
I pressurised to 2.0 this afternoon, switched-off the boiler and there was no movement for about 5 hours - if that isn't conclusive I'll try again another day when I can leave it longer.
