I have an Ariston combi boiler. It's apparently about 5/6 years old, but we've just bought the house so I'm not certain.
The central heating is fine, and the water comes out nice and hot, except that I had to turn the pressure down on the inlet to the boiler to ensure that it is consistently hot. I have set the water temp on the boiler to 4 out of a possible 6. I've no idea if that's normal because the instructions I have do not actually give you any information, but it appears realistic at a glance! Now the pressure is OK, but not great - sufficient to run a slow bath. The problem is that it is not sufficient to run the thermostatic mixer shower in the bathroom. The only way that I can get hot water out of it is by turning it on so little that it's just a dribble. As soon as there is a decent flow it becomes luke warm.
So my question is, is this likely to be a problem with the boiler? It's been superficially checked by British Gas when they flushed my central heating out, so it's safe, but it does make a few clanking noises and stuff.
Am I being overly optomistic in expecting a decent pressure from the hot water supply, or would a fully-working boiler be able to produce this?
Thanks for reading this far!
