- Joined
- 25 Aug 2007
- Messages
- 12
- Reaction score
- 0
- Country
We have just installed a series of lights illuminating an internal stair. The lights are small rectangular banks of LEDs (connected in parallell) operated by a two way switch (one switch at the top of the stair, one at the bottom). The lights work wonderfully however one of the lights (the one at the top of the stair and closest to the power supply) only dimms when either two way switch is thrown, whilst the other two lights switch off successfully.
I have undertaken the following diagnostics already without success:
1. Called the lighting supplier to ask if this was a common problem with these lights
2. Tried replacing various wires and switches
3. Tried bypassing the first light - intersetingly this resulted in both of the remaining lights only dimming when they should have been turning off.
4. Checked some of the more accesible junction boxes and switches for a short or bad earth.
5. Connected the circuit to an independent circut from the same main swiich board.
I have successfully connected the LED fitting directly to the same power source using a simple single switch setup and the light worked successfully. When I reconnected the single light to the two way switch system and flicked it off, the light only dimmed again.
Any assistance would be appreciated.
