caping of a toilet soil pipe
2 May 2006
Glasgow
i'm removing an old toilet, there is 110mm soil pipe. do i need to do anything special to seal it off or can i just cap it off with a plastic cap plus some sealant and be done with it. This is the only toliet in my flat that use the main soli pipe, the others all use saniflow style arangements. I'm the top flat in a block of three.
thanks
e
You can buy a purpose made end cap to seal it off with-if you ask in the builders merchants they will sort you out.
chr15 said:
...if you ask in the builders merchants they will sort you out.
Yeah, but don't just go in there and ask if someone can "sort you out" - something unexpected might happen. ;)
If you want another pointer, it would be: don't rely entirely on Saniflow toilets.
