Capping chimney(s)
8 Jul 2011
Hi all,
We've just moved into an old house (end terrace) which has four chimney pots (the chimney is on the end wall). Only one of the fireplaces are used, in the front room there is a wood burning stove, but the other three fireplaces have been bricked up and plastered.
We noticed a few little damp spots forming on the chimney breast just below the ceiling above one of the bricked up fireplaces. We were advised that the problem was that when bricking up the fireplace, there was no vent (airbrick) used to allow the air to circulate, and so damp has formed in the chimney. So to remedy this, we drilled a few holes at the bottom of the bricked up part of the fireplace and stuck a vent over it. First of all, was this a good idea?
Now, I'm looking to get the chimney's that aren't being used capped (with a cowl, is that the right piece of kit?), to stop rain and birds getting in, but to keep air circulating down it.
Is this the correct thing to be doing to get rid of the problem we are seeing?
Many thanks.
Better than nothing I suppose, it maybe enough, maybe not; you really need proper vents in there.
Hopefully.
http://www.birdstop.co.uk/c_cap_disused_chimney_cap.asp
or similar
Hi Richard,
Thanks forth reply. What do you mean by "proper vents"? Is there a specific type or way to vent a fireplace? Also thanks for the link, that's exactly what I'm after.
Thanks.
You are spot on, blocked up fireplaces must be vented to stop damp.
Just buy a standard vent, one of the ones that can't be shut off and make sure they aren't being sealed up.
Also chimney caps are a must to stop the rain going down inside.
Thanks a lot guys for the replies, very helpful and much appreciated. Going to call a few people tomorrow about getting the caps fitted.
