Car port - Roof!
7 Feb 2012
Derbyshire
First post. Just moved house and it needs a few things doing to it. As a inexperienced DIY'er I could do with your help.
It has a car port that runs up the side of the house and joins the garage. It has a flat felt roof.
The roof is leaking in two places and all the paint is bubbling and peeling off.
Are these two linked? So is the water making the paint bubble and peel?
I presume that the paint bubbling is near to the leak and not just constant. I imagine if the roof is in need of repair the paintwork and any soffits may be in need of some work.
It’s not uncommon for timbers to be untreated upon installation and treated after. Therefore any water ingress could potentially (and likely) be getting into the wood, making it swell and damp thus damaging the paint.
Check the condition of the timbers, fix the leak. Its a reasonable DIY if you are game for it
Thanks,
The paint is bubbling and peeling all over. So far I have only found 3 leaks.
Maybe the water is coming through and spreading throughout the base?
Is the base the same thing as the soffits?
I am not sure how these things are constructed, is it safe for me to get up there?
How would I check the condition of the timbers, are they the boards at the bottom (soffits?) or are they between the base and the felt?
Can you add them to your thread? Click on each photo and then add the DIYnot BBCode: to your post :wink:
