I have a Renault Clio Bebop 1994 which suddenly began overheating,the electric fan was not switching on.I bypassed the thermocontact and had the fan running permanently as soon as I started the engine,but it continues to overheat.I am now sure the problem is the thermostat which I intend to replace,however I am unable to find a tap to purge the cooling system.On the top right hand side of the radiator there is something which resembles a tap,which opens and closes something inside the radiator;there is no external opening.It turns 90 degrees from a vertical to a horizontal position,and I am unsure what it's purpose is or which position it should be in.Does anyone have any advice???
