- Joined
- 27 Jan 2008
- Messages
- 29,286
- Reaction score
- 3,598
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Please do not move to Cars, I want electrical opinions.
There have been two methods to charge a second battery, split charging diode, and the relay, main idea of both is to allow current from car to caravan but not from caravan to car.
However both methods are rather useless, on start yes may get 15A but 15 minutes latter luck if charging at 1A.
So today we have a third method, the DC to DC inverter, I have been looking at the Ring RSCD30 a bit bigger than I wanted, 15A would be ample, but it will also take the output from solar panels, however then comes the likely problem, it has a safety system to switch it off if the donor battery voltage drops to 12.6 volt.
Not exact as cars can use chassis return but with an alternator producing 14 volt then using 2.5 mm² cable your only permitted around 1 meter of cable at 30A.
Now using a DC to DC inverter I will only need to fit fuses in the car BS AU 177a wiring, so I have to decide before I wire the new tow car what I want to do. But £175 is great if the Ring RSCD30 works, but it is a lot of money if the unit keeps disconnecting on under voltage. And attempts to buy 2.5 mm² 7 core at local supplies have not been successful they only seem to stock 1.5 mm² cable.
The Ctek D250SA is a lower output, but £220 price tag is some what off putting. The Ablemail AMC12-12-30 seems to be OK, but can't find a price.
What I want is a device which if I leave a caravan site with a discharged battery two hours from home will put enough in the battery so I can use motor mover to get caravan to back of the house. The clear alternative is a second battery which if kept charged at home which I can swap when I get home.
So I would guess the device would need to put around 15 Ah of charge into the 75 Ah battery, so 8 amp average is minimum charge.
If caravan charging is out, then I wire car with 1.5 mm² cable and remove the battery to battery fuse in the caravan, if charging is an option even at a latter date, then need at least 2.5 mm² cable to wire car. So don't need to do job of fitting a DC to DC inverter now, but need to work out if it's a viable option before wiring the BS AU 177a to the car. BS AU 149a already fitted.
