None at all until someone changes a lamp with the switch off, thinking that the lampholder will be dead.Yes the light switches are in the neutral and what difference does that make,
But not against a L/E fault.There is still a fuse in the circuit protecting against overload.
It will do nothing for a L/E fault.There is still a fuse in circuit, the fact that it is in the neutral is unlikely to affect its ability to protect against an overload.
That's not the only difference.The only difference will be that the 13A socket's switch will be in the neutral
All fuses downstream of the socket will be in the neutral.
