Carbon filter for obsolete extractor
19 Aug 2010
Luton
HI all, I've got an obsolete extractor (Premium Appliance Brand Cat no. HDG620SS) which is not vented to the outside The carbon filter is blocked and seemingly unavailable but there are a couple of screws which, when undone allow you to remove 3 gauze a one felt (carbon?) filter.
My question is can I use a cut to size sheet to repair it and, if so, which material/supplier should I use?
There ar 3 gauze filters one thin, one thicker and one is ridged. Can anyone steer me as to which order they should be installed. I think a previous repairer put them in in the wrong order.
Any ideas?
In the last photo, there are 4 sheets, one thick one which I think goes closest to the hob, one bumpy (ridged) one which I think goes in the middle, one thin one which I think comes next (inside, facing the motor) and one black one which I think is the carbon filter. I guess I could cut one of the sheets you suggest to size but whick one would be best and where should it sit? My guess would be between the ridged one and the thin (inside) one.
I don't know, I've only had hoods with the canister-type carbon filter, and a single grease filter.
The carbon filter goes after whatever other filters or grills there are.
You might be able to find manufacturer's instructions for a hood of your type.
I don't use recirculating hoods as I consider them useless.
My hood has very similar rectangular screens [which don't appear to have any carbon filter in, and I wash them in the dishwasher], but the actual carbon filter is round, roughly dome-shaped and twists on to the fan.
Soak in VERY hot soapy water a few times or put in dishwasher on their own on a very hot cycle.
Both approaches will help
Are you sure there isn't a proper filter inside the unit?
