Hi
Anyone know if you can purchase a wider trim that goes from Laminate to Carpet? The only ones i have ever seen seem to be around 41mm in width (end to end) with the top cover strip being around 28mm. Due to a badly cut carpet i need one that needs to be quite a bit wider than 28mm, probably looking around 50-60mm in total. I have seen a 61mm carpet to carpet one but need one thats Laminate to Carpet.
Is it possible to get such a thing? are there any alternatives, i could attempt to stretch the carpet but its likely not to work.
L
L
