Hi everyone,
I’m attempting to fit a new carpet into a bedroom. First time I’ve tackled a full room, but it’s 2.8x3.6 box so should be as easy as they come. However... I can’t get the carpet to grip to the grippers!
Some info:
Many thanks!
Robin
Some info:
- I’ve put grippers round the skirting with a 6mm gap (seemed to be most popular advice online, however there was anything from 2mm to 10mm quoted).
- The grippers are the correct way round (angled side total the wall, spikes pointing to the wall).
- Underlay is 12mm thick (PlushWalk) and goes right up to the grippers.
- I’ve cut the carpet to about 100mm over on all sides.
- I’m using a knee kicker and a tucker to try and get the carpet onto the grippers.
- I can feel/hear the spikes going into the carpet backing if I push it down onto the grippers with my fingers, but it just lifts off again.
- The carpet is a Super Sublime saxony from Carpet Right.
- It is 15mm thick (12mm pile).
- The carpet backing appears to be a woven hessian type with a sort of thin layer of felty material over it (not seen this before, and don’t know if this then constitutes a “felt backing”).
Many thanks!
Robin
