- Joined
- 29 Sep 2016
- Messages
- 19
- Reaction score
- 0
- Country
Hello,
We are refurbishing our flat and need carpets for four bedrooms and a corridor, all on the same level, (60sqm net total area, about 75sqm if you take rectangles surrounding all rooms, about 85 sqm if you account for wastage based on carpet roll width of 4 or 5m).
Before we started shopping I had zero knowledge of the area (now I have only slightly more than zero!). We visited a couple of stores and looked at carpets and got samples etc. and then we liked this one from John Lewis:
http://www.johnlewis.com/john-lewis-easy-clean-soft-twist-42oz-carpet/p1913642
They came and measured the area and gave us a quote for fitting it. At that point I noticed they added a cost for underlay, this particular one:
http://www.johnlewis.com/john-lewis-crumb-rubber-underlay/p2501091
As I said, at that point I had literally zero knowledge, I didn't even know there's a separate underlay, so I started researching and realized that the choice of underlay is very important, possibly even more so than the carpet. And that this particular JL one is probably the same as the Duralay Treadmore that can be had for half the price online. I asked JL and they don't have issue for me getting the underlay myself, so I'm going to do that, and I would like recommendations for underlay. I would like a soft feel, and also the flat is at ground level, so higher tog rating may be better from an insulation point of view. From what I read in various forum posts the Tredaire Dreamwalk 11mm is a good option, but there's potentially a concern of being too soft and therefore losing shape over time, even though it's described as heavy domestic usage. Then I looked at the Tredaire Colours Red 11.4mm which seems more durable and firmer, but still comfortably soft. The Axminster Axfelt65 is also recommended by many, but I'm not sure exactly what the benefits over the others are.
And then there's the carpet itself. Any views on the particular JL one? A recommendation perhaps for a similar (or better) alternative? Given the presence of two young children I would like something durable, stain resistant rather than fancy. And I have a preference for manmade material, as opposed to wool or wool blend as I feel it offers better value (unless you convince me otherwise). One of the reasons the JL is the front runner at the moment is the perception that it is a decent quality product that will do the job, and the company will stand behind it in case of failure. I would like to use the analogy that (I think) it is the Volkswagen equivalent option, but with the caveat that it would refer to a non-diesel model
If we can have something like that with another product that we can buy online or from a local shop and have a local fitter install, I would be fine with it.
Thanks very much
Thanks very much
