Carrying on the CPC past a Quinetic receiver.
25 Jan 2010
Bristol
Quinetic receivers are live and nuetral only, no pass through for the cpc, whats the best way of ensuring that the cpc carries on to the fitting. The sheathing clamp and housing on the receiver is not big enough to take a waggo between it and the units terminals ... use an inline crimp ?
I think there is just about room in there for a single unit of small screw terminal block, though I was using pretty small cables.
There is also the option of just not cutting the CPC at all. Particularly if you are using flex.
Pass the in and out through a junction box, where you'll do all your connections then take a 3 core and earth to the receiver.
