I am asking on behalf of a friend who has a combi boiler system in a normal sized 3 bed semi.
He intends to swap a normal radiator for an old cast iron one as this is the look he is after.
The question is if he alters the pipework to suit the new cast rad will the pipework being in 15mm be ok for the new rad or is it likely to cause problems?
Not 100% sure of the size of the cast radiator but think its approx 800 by 600.
Also are both flow and return ok to come in and come out the bottom like a normal radiator instead of in the top one end and out the bottom the other end?
Thank you for your time.
