    Dismiss Notice
Cast Iron Wood Burner Restoration
Discussion in 'General DIY' started by bmouthboyo, 16 Apr 2019.
  1. bmouthboyo
    bmouthboyo
    3 Jan 2018
    88
    Thanks Received:
    Country:
    Hi guys,
    Couldn't find a dedicated UK forum for this so thought I would ask here.
    I am making a little outdoor covered area that has walls on 3 sides (garage, house and extension) with a poly-carbonate roof. Want to add a heat source for summer evenings and so picked up this wood burner for £50 off Facebook marketplace locally.
    [​IMG]
    I wouldn't mind sprucing it up a bit and will need to fix a few bits as well as add a flume.
    Firstly the flume attachment has the tabs broken off:
    [​IMG]
    All the tabs are present but as it is cast is this weldable?
    Any general advice for restoring it on the cheap?
    • Like Like x 1
  2. bernardgreen
    bernardgreen
    3 Nov 2006
    21,071
    Thanks Received:
    1,910
    Bedfordshire
    Country:
    The Hetas website has a lot of advice about how to safely install a log burner.
    It is not just "stick a pipe through the roof" when installing a flu system.
    What ever you do spend some money on carbon monoxide alarms. They might just save your life, especially if the fumes from the flu can reach windows in the house..
    https://www.hetas.co.uk/consumer/hetas-advice/
  3. Ian H
    Ian H
    14 Sep 2010
    5,446
    Thanks Received:
    588
    Rochdale
    Country:
    I like your idea!!! If your extending the flue upwards you may be able to seal the extension in with fire cement.
    Any idea what you will paint it with?
  4. Burnerman
    Burnerman
    7 Feb 2008
    19,235
    Thanks Received:
    3,718
    Northumberland
    Country:
    Those tabs are fixable, I don't think anyone would be prepared to weld them though, so seek out an old time blacksmith with oxy acetylene gear who is prepared to have a bash bronze welding or brazing them for you. I can't really see what they are meant to do?
    The flueing requirements would be twin wall at the very least with an appropriate flashing to go through the roof.
    Manufacturers such as Morso do their own paint for woodburners but I'd guess any very high temperature matt black paint would do.
    Is there a large baffle plate on the inside of the stove, covering the flue outlet?
    John :)
  5. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,891
    Thanks Received:
    308
    Country:
    Does it have its firebricks, or are we looking at rusty cast iron inside, in the photo?
  6. bmouthboyo
    bmouthboyo
    3 Jan 2018
    88
    Thanks Received:
    Country:
    Sorry should have been clearer. This is for outside:
    [​IMG]
    About where it is in that image and there will be a seated bench where the stainless table is. The flue will come out the back and past the poly roofing.
    The tabs secure the flue spigot to the rear to stop it dropping off. A bit like this intact cover from the top:
    [​IMG]
    It does have firebricks which I have removed for now:
    [​IMG]
    Given that it will be out in the elements I am not sure if painting it is the best route as I was hoping to just use stove oil.
  7. jasonzyx
    jasonzyx
    6 Feb 2019
    1,618
    Thanks Received:
    19
    Country:
    Is it possible to drill and tap cast iron?
    • Like Like x 1
  8. bmouthboyo
    bmouthboyo
    3 Jan 2018
    88
    Thanks Received:
    Country:
    That isnt a bad idea as it only really needs to hold it on as I will seal with fire cement.
  9. Burnerman
    Burnerman
    7 Feb 2008
    19,235
    Thanks Received:
    3,718
    Northumberland
    Country:
    Dead easy to drill and tap cast iron......you could have a piece of bar across the inside of the stove, secured to the faulty spigot.
    John :)
  10. lostinthelight
    lostinthelight
    11 Feb 2016
    1,148
    Thanks Received:
    190
    monmouthshire
    Country:
    The tabs are wedge shape so lock the collar to the stove when twisted so very difficult and expensive labour wise to get them gripping evenly.
    Ive done a few by drilling stove body, colar, tapping the latter and bolting up through with large washer under the head which keeps both parts together m6 bolts are my preference.
    If taps are not available, 6mm clearance holes can be drilled through both parts and nuts and bolts holds together with the addition of the large washers inside the stove
  11. Burnerman
    Burnerman
    7 Feb 2008
    19,235
    Thanks Received:
    3,718
    Northumberland
    Country:
    Yep, now that Ive seen what those tabs do, welding is impossible.
    John :)
Loading...
Share This Page
