Rented property, apparently shower leaking. water dripping into kitchen located under the bathroom.
Inspect over-bath shower, nothing other than a tiny dribble after I ran it and showered walls & bath rim for 3 mins.
Bathroom Floor boards soaked and mouldy, kitchen cieling sagging.
Drip from both fixing bolts of close- coupled WC, the type were the nuts run through the bottom of the cistern. Found the equilibrium float valve diaphragm split hence cistern overflowing. Internal overflow; rubber dougnut knackered, but presumably not enough to be noticed when toilet flushed.
Glad I didn't fit this lot. I've fitted similar, glad I'm insured now.
I'd say the installation was a fair job, It's the kit that is to blame for this mess. External overflow - wouldn't of happened.
