If I calculate the CCC for a 2.5mm cable to be X amps using a particular installation method, is it true that if I use that cable with that method as a ring, then the CCC of that cable in the ring is 2X amps? (as assuming even load the current is split down each side of the ring). e.g. if the calculated CCC of the cable is 27A, I could either install the cable as a radial with a 20A MCB, or I could install it as a ring with a 32A MCB, even though the CCC is 27A, because actually each side of the ring could take 27A = 54A total load? Is that right?
