I was at a cctv fault the other day and the system comprised of a DM sprite 2 and 16 cams. The fault was that the sprite was "freezing" every now and again and had to be restarted each time. I called up tech support and the guy said the problem was the video signals coming from the cameras were not at 1v p-p as they should causing my problem. I can get myself a video signal monitor to tell me the signal so that is fine but my question is this, if any given camera is not at its 1v p-p signal can this be altered to become 1v p-p and if so how is this done, or does this mean the camera is faulty as it is giving out the wrong signal and requires replacing?
thanks guys in advance for your comments
