No doubt a regular subject but help required.
Moved in a year ago and inherited the previous owner's son's DIY bedroom electrics!
Bedroom currently has 2 sets of 3 LV downlights (instead of a ceiling rose) attached to a single dimmer. One transformer has now packed up (and I found a discarded transformer (also unusable) in the loft amongst the wiring) so probably a recurring problem.
All light fittings need replacing so I am looking to use 6 mains halogen (50WGU10) with 1.5mm twin and earth cable and a 400W dimmer.
Questions:
1. Am I best to connect all together as one chain or split the supply into 2 (as at present)?
2. Junction box or would cable block connectors be OK?
3 The current switch live supply does not appear to be marked. Am I safe to assume the current connection to the live input on the transformer is the switch live or should I check with a circuit tester. i.e. adopt the "mark what went where" approach
4. Think I understand the wiring and I understand to keep the earth connected but does it just terminate at the last fitting?
5. My biggest concern is the heat. This is in the loft and there is new thick insulation everywhere. I presume best not to lay insulation back over the wiring and fittings. Would boarding laid over the rafters with insulation laid back over the top be OK? Problem is newish house so rubbish rafters only about 2in high. Are there heat shields available?
Reply in words of one syllable please - you can guess I'm far from being an expert.
Questions:
