ceiling fed showers
1 Mar 2007
Suffolk
i am looking into fitting a shower to run off my combi and was thinking of getting a mira thermoststic valve with swivel inlets to allow surface mounted pipes but i have just noticed that bristan do a twinwall pipe that contains hot and cold using a smaller pipe within a larger pipe that also acts as the slide rail.anybody got any views on these or should i stick to a normal valve,any opinions would me much appreciated,cheers.
Have fitted loads of mira and 1 bristan of which you mention. Mira are great, bristan ok. Main problem I think is the bristan cools the hot as it comes down the rail resulting in a cooler shower, not to say cold but it goes against all logic.
By the same logic, does the hot not also warm the cold?
ummmm now you got me thinking :roll:
yes your right. the hot was too cold and the cold was too hot.
