P
peaps
If you are going to render it then I would use lime. I come from Yorkshire and did much of my training on old stone builds Done a few houses around greenhead park, marsden, honley etc. You can Kingspan it but it would be advisable to insert small vents to help the wall breath.
Problem we face these days is that people want to keep there house warm, gone are the days when you can keep all your open fires roaring and central heating comes with it's own problems, condensation is one of them because they seal the house from draft. Coupled with cold external walls and no air flow you get condensation problems.
Catch 22 situation but you CAN use modern methods if done correctly but you can't but gypsum based products directly onto stone and not expect problem down the line.
i live in marsden, and the house im doing is on manchester road in linthwaite. I wouldnt use gypsum on stone, but when you say vents, where would you put them? so you can still see them once you have boarded it? the plan i have is the gap between the old and new wall, i intend to leave a gap in the ceiling, so there will be an inch or so gap so the air in the loft ( there are vents) comes down behind the new wall.
The reason I wanted to render it was to stop the penetraiting damp coming in....the render is only for this purpose, so what mix would you use?
Ah do you drink in the Sair? Will reply in a whie o some chickens to sort out.
