I'm hoping somebody might be able to help me.
Currently in the process of changing a light fitting, I've identified all the wiring everything seems to make sense. The only problem I have is the manufacturers instructions tell me to "position the terminal block outside the backplate in the ceiling void"
This is a problem as I don't have room to fit the terminal block in the void, and these instructions don't take into account the extra loop wires that need a separate terminal block.
The previous fitting had the L/E/N terminal block and a separate loop terminal block inside the fixture. There is room for me to do this in the new fitting, I just wanted to know if it was OK to do this?
