I have just bought a new light fitting and have come to install and am slightly confused.
The existing ceiling rose is of the standard configuration.
3 live into the central terminal ( 2 supply, 1 switch )
3 earth into another terminal ( 2 supply, 1 switch )
2 neutral into a terminal ( 2 supply I think )
1 neutral into another terminal ( from switch I think )
With the 2 existing light fitting cables going to the 2 neutral terminals as you would expect.
http://media.diynot.com/23000_22848_53193_53402673_thumb.jpg
The new light fitting however has only 3 terminals, live, neutral and earth.
http://media.diynot.com/23000_22848_53194_51610074_thumb.jpg
The fitting comes with a spare single terminal block.
The existing ceiling rose needs to be removed, that's not problem. However I'm confused as to how to wire this up, mainly because the instructions have now caused me some confusion.
They state
"Where a ring/loop circuit exists, there may be a seperate set of wires which are not connected to the L,N or E of the fitting. They must be kept together in the vacant (loop) termial of the block supplied, or in a separate approved block (Not supplied ) and insulated from the rest of the fitting.
I not aware of any " extra set of wires".
Do I just take the L, N, and E of both existing supply cables and the existing switch cable, and connect respectively to the L, N and E of my new fitting?
This is probably obvious to most, maybe i'm thinking too hard about this, but the instrcutions make no mention of what I'm supposed to do with the existing switch wires.
It goes on to say
"Connect the supply wires to the terminal block of the fitting"
Again but makes no mention of the switch cables/wires?
Help!
They state
It goes on to say
Help!
