can anyone advise me? i am fitting a sump in my cellar ,i bought the house recently, there was a trench dug in the concrete floor to take water out. its been completely dry for 6 months and i am told it has been so since other houses have been built around me
(the last 6/7 yrs). anyway i will be absent a lot and wish to know i have any problem covered. so i am fitting the sump and a submersible. the question is. am i to leave the sump so that water can get in from its bottom and walls? thus allowing the pump to drain the sump before the level rises to the cellar floor itself. or am i to seal the base and walls and wait until the level in the ground is such that any water seeps in through the cellar walls ,then runs into the sump to be pumped out. i think the first solution is the best??? so long as any incoming (rising) water does not overcome the pump (unlikely) or the pump fails to start (possible) but applicable to both designs...!!
