Hi all
My 13 year old Potterton Envoy Flowsure Plus has developed a problem. It is covered by Domestic and General who contract Baxi Heating. The boiler is a condensing combi boiler with a 50L sealed hot water storage tank. The storage tank has a T and P relief valve on the top and a few weeks ago it started passing. This has happened once before years ago and the Potterton (Baxi) engineer replaced the valve and all was fine again.
So, I called D&G and an engineer came out. I told him the valve needed replacing on the hot water tank and he said it was "kettling". He then proceeded to replace the pump and showed me the old pump which had some sludge on it and told me that I needed a power flush.
I'm not completely ignorant and lacking of common sense but it occured to me that the valve passing has nothing to do with the pump but he disagreed and buggered off telling me it was sludge that was the problem. Once the boiler had heated the tank again, it started passing and a day later it was also passing when the sytem was completely cold which confirmed to me that the valve needed replaced as there couldn't be any over pressure in there when cold, right?
Next I contacted D&G again and they told me they couldn't send anyone out until I had got a power flush done (£300-£400) to remove sludge. I disputed the engineers diagnosis and they agreed it sounded wrong, so they sent the same guy back out who this time agreed and told me he couldn't get the part and buggered off.
I looked up this part on the net, contacted a few suppliers and they had the part in stock no problem. Relaying this info back to D&G they said Baxi can only use certain suppliers but if I could get the part fitted by a 3rd party plumber/enginner then fine, send the invoice and they will pay for it.
So, new part fitted and no problems for a few days other than needing to top up the water pressure even though I can't see a leak anywhere????.
This morning I was having a nice hot shower and heard the overflow ****ing water outside and to my suprise, the new valve is passing but only when hot.
Now I need some impartial and proper advice, does this system need a power flush to cure the problem or is there something else going on here? Should I get D&G back to this? They think it's sludge and are hesitant to come back until I've had this done.
PS the engineer said it would be fine for a few months after he fitted the new pump.
I pay D&G £20 a month and this is the first repair for 2 years, so that's £576 without a call out and naturally I'm keen not to get ripped off/fobbed off and spend another £300-£400 on a power flush.
BTW the boiler is also making a rattling noise since he replaced the pump and I found a screw lying on the floor under the boiler!!!
