I've had a central heating system installed, fed from an existing fused spur. I thought I was getting plastic piping through out but the plumber has used copper with several plastic joints throughout instead.
If I am correct the wiring regs do not require you to earth each radiator (4mm sup to local socket) if there is plastic piping and the connection from directly under the floorboards to the radiator is copper. ie only 10 inches of copper to the radiator.
What are the earthing requirements if the entire system is copper piping but at each radiator there is a plastic elbow just under the floorboards? Thus the radiator is actually insulated.
Any ideas? I'm trying to avoid riping up floorboards to supply a supplementry earth to each radiator if it is electrically isolated due to the plastic fittings.
