I'm also thinking of a creating a wiring diagram for the system as it stands now and posting that on here.......
Very good idea. Make sure you label everything: component, wire colours and terminal numbers, including in the junction box (say which end you start).I'm also thinking of a creating a wiring diagram for the system as it stands now and posting that on here.......
What type of junction box are you using ? 10 way choc block or one of the honeywell wiring centres ? last question do you know what contacts fused together in the cylinder stat ?
I think my money is on damaged cabling between the boiler and cylinder.
As you are an engineer could you temporarily (but safely) run new cables between the two areas, possibly up the stairs etc and run that for a few days?
I don't think the electrician insulation tested them thoroughly, he needs to test each wire in turn with each other wire, and not just test them to earth.
Shame you are not closer to Kent.
having had a fairly close look at the wiring in your older post, it appears there are 4 cores connected to the cylinder stat. Can you confirm this is the case or not as that would be most unusual, and if it is so, could well be the cause of your problem.
The two blacks used in one terminal is the lazy way, IE you dont need to find out which one is which.
You could buy 100m of 3 core flex and run two of em![]()
(3 core is cheaper and your more likely to use it up).
Just looked at your picture again, you would need a lot more than 4 cores anyway![]()
