Hi, I had a problem with boiler bypass a few months ago getting totally blocked with crud.
I've decided I want to install some sort of inline filter to my open system.
The best/easiest place to install would be on the return pipe to the boiler that's in the garage.
The only place that it can be fitted would be a horizontal section that comes through the house/garage wall at ceiling height and continues at ceiling height to opposite wall where it drops down to top of boiler. There is only about 3 inches of straight vertical pipework so no room to fit there.
My question is, what would be some decent recommendations for a filter that could only fit pipework horizontally, and pipework is less than 40mm from boarded ceiling.
I was going with Fernox TF1 which can be fitted on horizontal pipework but then read it needs 150mm clearance above pipework to clean out.
Thanks for any replies.
