central heating fusing when boiler fires up
15 Dec 2005
Leeds
As above,been working fine until w/end,checked wires for something obvious but can't see anything.
What exactly is "fusing" when it fires up?
You might also like to try the plumbing forum, giving a bit more info on the equipment you have and the fault details...
Process of elimination.............could try disconnecting the wires to the pump, and see if it still fuses when boiler fires up.
I only say the pump as I got called out on a job before christmas and that turned out to be a buggered heating pump.
