Hi wonder if anyone can help when i switch heating on and rooms get
to temp i start to get a high pitched whine from boiler one of two things stop
this 1 turning hot water tap on stops the whine and 2 one of the radiators being turned fully up stops it , turning the radiator up seems to be the strange thing as its a specific radiator that only takes noise away which is on our top landing of the the house
Here is what i have tried so far
bled all radiators
took said radiator off and flushed out
changed thermostatic valve on radiator
bled tank on bolier which seemed to have a lot of air in it
and drained system 3 times
All of the above still doesnt stop the whine when valve on said radiator is set at anything
but high all other radiators can be set at different levels
I have an old boiler but has been working great for past 12 years that i have been in house its had the usual things replaced over years such as flow switches and fan, thermostats etc but cant get to botttom of this its a vokera 20/80rs flomatic
Gary
bled all radiators
Gary
