I have absolutely no clue about boilers whatsoever so I'm looking for some advice in case its a simple issue. Basically none of the radiators are heating up but they are all slightly warm to the touch. It doesn't matter what temp I select on the thermostat. The status on the boiler says C and the burner light is flashing. The water heats up fine, although a littler slower than it usually would. I noticed the pressure gauge is on about 8 PSI but have no clue if that's anything to be concerned about. Any help appreciated. Its an Ideal HE35 boiler if that makes a difference.
Thanks.
Thanks.
