Moved into a new property
2 bedrooms which have microbore pipework single radiators
Downstairs 1 single, 1 double and a towel radiator, 15mm pipework
In our previous (larger property) when putting on the central heating the boiler would run at full pelt (I think the term is full rate) where you could hear the fan running etc within a short time frame the house was nice and cosy, albeit it was an ideal vogue combi boiler
In this property we have a Vaillant ecotec pro 28 boiler, I can't hear the fan running when the central heating is switched on and it doesn't appear that the boiler is running at full rate, it takes at least an hour plus for the radiators to get really hot.
When I open the taps I can then hear the fan run and the boiler run at full rate!
Is this normal behaviour for the vaillant boilers when running central heating?
I also found this part underneath the floorboards any ideas what this is? Has it been set correctly, could this be causing the above mentioned issues with the central heating?
