I have a Glowworm Compact 100 boiler. The boiler fires up ok, but often (not every time) shuts down after approximately 30 seconds (although the pump continues to run). This happens when either the hot water or central heating zone actuator valves are active.
I had a problem a few years ago which I vaguely remember had similar symptoms, and the hot water value actuator needed replacing. Could it be the same again ?
I'd appreciate any advice on what the problem might be, particularly if it is an valve actuator
John
John
