Hi
I have a gravity feed heating system, it is a pumped central heating and I'am not sure about the hot water side. The problem i am having is that the heating is on full heat, when ever it is on and my house is like an oven. My set-up is :
Boiler is oil fired ;- Boulter, Camray 5
Controller ;- Centaurplus C27
Thermostat ;- Drayton RTS1
The controller works and turns on and off when it is timed to and boost when asked too. The Thermostat clicks when turned, so i am at a loss as to why it will not turn off when the set temp is reached..
This was a problem to wards the back end of the winter this year when the thermostat stopped clicking and it heated to full heat all the time. I have replaced the thermostat and it still appears to be at fault.
Not sure if this is relevant but i read on another forum that if you remove the thermostat them turn the advance button on the controller on it all lights up and still fires, dose this mean there is a problem elsewhere?
Rob
Rob
