We had a plumber in about 6 months ago who fitted a new radiator. At the time when we re-filled the system it took a long time to get going and in the end he moved the lever on one of the electronic valves to force the heating to come on. So that meant that when hot water was on, heating was on too.
anyway i then put the lever back into normal position out of override and all seemed fine - the heating was off, the hot water was on, it was summer, all was good.
The problem now is, that the heating no longer comes on via the thermostat. So it works if i go back into the override mode, but thats not much use as it's just on and off!
I wonder if anyone has any ideas of anything i can check or do before I call a heating engineer in? I had a problem with a pump once before and was able to fix it thanks to advice in a forum, so fingers crossed!!!
Thanks!
Dan
Thanks!
Dan
