Hi
I can't thank enough - but thank you so much for taking time to explain all the steps in detail.
The boiler is now playing again with low pressure - it's now losing 0.1 bar every day. As you said, it might be due to the air being let out by the air separator (not the vent - but a separator from Spirovent).
I think they are not modern radiators, they are barlo radiators - just like this one - https://www.amazon.co.uk/600x1000mm-Quinn-Barlo-Compact-Radiator/dp/B00ADETULI
I must say some of them are really huge like 500 x 2000 DC.
I mostly understand most of the steps you have listed above. But am bit struggling to understand the bit where I connect pipe with the radiator bleed valve.
One end of the pipe is in bucket, is the other end connected to washing machine tap and the other end of the washing machine tap is connected to radiator valve extension. So is it basically "Radiator bleed valve -> radiator valve extension -> washing machine tap -> washing machine pipe -> bucket"?
Sorry, I know I'm being rubbish, but I know only very little diy.
Thank you , again.
If you have modern radiators (with the largeish fitting holes at the radiator tops as well as at the bottom) then a handy way to do this is;
- Remove one of the inserts at the top of the radiator (they're usually chrome, one will have the bleed valve in, the other will be blank. If you have a spirit level, remove the one at the highest end of the radiator- it should be the bleed valve one but best to check if you can.
- Insert your pipe assembly, threaded end first, into the hole, wind it all the way in
- Switch the washing machine tap OFF
- Fit the washing machine pipe to the washing machine tap, make sure the other end of the pipe is in the bucket (you might want a brick in the bucket on top of the pipe to stop it flying out when you do the next bit)
Thank you , again.
