My grandparents are having a major headache with their heating. They bought the bungalow recently and have had the following work done:
The previous system was removed - the CF wall boiler, flue, cylinder, expansion tank and pipes not in use, lounge radiator rear the kitchen and capped pipes close to the floor.
New Worcester Greenstar 25si combi boiler installed on 11 July.
Power flush 14 July.
Checked 25 August
Boiler topped up (repressurised) 1 September as pressure dropped
Pressure dropped 7 September - heating engineer called and they suggested there may be a leak
Pressure down to zero 16 September
Heating engineer isolated boiler, left on 1.5bar 19 September
Boiler remains 1.5 bar 20 September
Heating engineer checked on 23 September, no change in pressure, advised not boiler problem.
Trace and Access specialist (ADI Leak Detection) - repressurised boiler, traced pipework using thermal camera, no problems detected. Drained system and pressurised with tracer gases at 2.5 bar for over an hour. Found no drop in pressure. Checked radiators and found most loose and new radiator very loose on fittings so they tightened them. Refilled system. Inhibitor and Leak seal re-added to system.
30 September Worcester Bosch engineer - switched off central heating section, to check pressure - isolated boiler, pressure did not drop over 3 days. Unable to check entire boiler as part of kitchen needed to be removed for access.
Worcester engineer revisted 4 October - fitted new heat cell to eliminate boiler from pressure loss on system, had boiler on test for 4 days, no drop. Checked expansion vessel and P.R.V all ok. Pressure left at 1.5 bar.
By 5 October the pressure had dropped right down to the red section, by 6 October it was back at zero (previously pressure dropping over 3/4 days).
Does anyone have any ideas please as we're running out of ideas and this has been going on a long time now?!
There are no obvious damp areas or leaks but all the pipes are beneath the concrete screed floors. Shouldn't the leak detection have found any leak if there was one and it was done properly? Has anyone got any experience of the company used (www.adileakdetection.co.uk)?
There were a couple of replacement radiators installed with the new boiler but 5 existing ones remain.
Thanks in advance!
Checked 25 August
Thanks in advance!
