I have recently moved into a new house. When i opened the airing cupboard board where the cylinder lives i noticed the lever at the bottom was set to flushing rather than normal use. A hair band had been used to keep the lever set to flushing.
The heating woks this way and the water gets hot.
however if you put the lever to normal use nothing works at all.
also the thermostat has no effect when on flushing setting.
And in addition to this when you turn on the emmersion switch i the kitchen it trips the main fuse!!
help
help
