Hi I could do with peoples input into how my heating system has been plumbed.
I have a problem where there are 2 radiators in the front room of the house that heat up fine when just the heating is on but as soon as the hot water goes on too it makes the these 2 radiators go cold.
I have balanced all the radiators in the house by closing all the lockshields down and opening the downstairs ones a quarter of a turn and the upstairs ones until the radiator gets warm.
I think that when there is demand for the hot water and the zone valve opens it bypasses the flow and means that the water takes the easiest route back to the boiler.
i have attached a picture of the pipework layout to see if you can see any problems.
I have several questions regarding the plumbing but need to try and get this one resolved first
pipework from left to right
Boiler flow
Boiler Return
Radiator flow
Radiator Return
Hotter out
Cold water supply
cheers
Boiler flow
Boiler Return
Radiator flow
Radiator Return
Hotter out
Cold water supply
cheers
