Hi all,
I have recently paid an electrician to do some fairly basic work in my lounge, move some sockets change the lights etc. He offered to change the central heating thermostat, as the existing one was a) old fashioned, and b) hanging off the wall.
I remember that someone a while ago said changing it would be tricky as you would have to get a similar one but my electrician assured me it would be fine.
After Nick (the electrician) left, the hot water clicked on as normal, and was running fine until I decided to check the new thermostat by turning the heating on. Instantly the RCD shorted on the main fuse box. I switched the RCD on but the central heating programmer did not return. I have changed its own fuse but it seems to just not be having any of it.
Naturally Nick has now disappeared of the face of the planet when I need some advice after I had to check his work!
Does anybody have an idea of what I should do next? Could it be the water pump (common suggestion)? or could the programmer have just died? Incompatible thermostat?
Any advice would greatfully be received.
Thanks in advance
Chris Maile
Thanks in advance
Chris Maile
