I have a combi boiler central heating system. It is controlled by a wireless digital room thermostat. I have the system set on constant, the stat controls temp OK. When room temp is reached the boiler switches off OK as heat is no longer called for, the pump runs for a short while after switch off. The rads then cool down until the room stat detects sufficient temp drop and then switches boiler on to call for heat. My query is should the pump keep running to circulate the hot water in the rads to maintain some sort of constant temp after the boiler switches off?. My system is fully maintained and serviced by gas safe engineers. Thanks in advance for any replies.
