hi
I moved into a new house a couple of weeks ago (built 1965).
It has a Potterton Suprima 50L, installed in the attic in 2004 by BG.
I immediately noticed a continuous noise coming from the attic at night.
The heating seemed to work OK - but then one morning it didn't start.
Called a local reputable plumber out - we confirmed the pump was receiving a continous signal to run from the boiler. The boiler was reset and has been OK for a couple of days.
He then told me of the infamous PCB problem & advised I call Potterton. Fortunately my serial number is covered by the replacement program and an engineer is coming tomorrow to check the boiler & replace PCB if necessary.
I've read about the boiler cutouts being a symptom of the fault PCB - but is the continuous call to the pump likely to be part of the same problem ?
thanks
swayzak
thanks
swayzak
