- Joined
- 6 Jan 2017
- Messages
- 5
- Reaction score
- 0
- Country
I am trying to discover whether I need to upgrade my central heating pump.
I had an existing heating system updated and re piped by a heating engineer but all did not go according to plan and he left the job having not fully completed the task, he suggested that one of the problems he couldn't fix which was the radiators not heating fully, was because of an undersized pump but seemed unable to recommend the correct size other that telling me it needed to be "larger", so trying to understand what size I require.
Currently have a Grundfos UPS 15-50 130 which heats everything up to radiator 'G' fairly quickly and to a good temperature but radiator 'H' and 'I' don't really ever get beyond luke warm.
He originally balanced the system and I have since made a few adjustments but probably not correctly and still doesn't really improve.
All the radiators are existing cast iron column type that have been flushed and all the pipework is new 22mm speedfit
The area in use is an 1st floor zone and there are plans to re pipe the ground floor at some stage and add it in as a second zone but only using the one zone for now.
Any thoughts would be appreciated.
