Central Heating pump speed
16 Sep 2004
Leeds
Is there a general rule for what speed setting your pump is set to? Currently, mine is on full (3). It's a conventional system with water cylinder and CH F&E tank in the loft. There are 13 radiators in total, 2 of which are double, others are single.
useally average house is fine on 2
Hi, thanks for the reply. I have 13 rads, what is an "average house"?
I have set the pump to position two. What symptoms should I look out for if the pump is struggling on this speed setting?
1. Is the boiler overheating, i.e temperature rises very quickly and then the boiler cuts out?
If "yes". The pump is not moving the water fast enough. Set it to 3
2. Are all radiators heating up OK.
If "no", the pump pressure is too low. Set it to 3.
Has the system been balanced? If not read How to Balance a CH System
Pump speed and Balancing are linked.
"garrymum" i think i recall you wanting to retrain as a plumber are you sure your question is about your house or is it just for knowlege on your jobs??!
are you leading us up the garden path with your question!?
