Hello, I need some help please
I have an open vented central heating system with a Potterton Profile Boiler. Probably 25 years old
I was having trouble getting all of the radiators hot at the same time, by turning the upstairs off I could get most of the downstairs hot for a while and vice versa, but the temperatures would go up and down. The pump was making very loud whirring noises, so thinking it was the pump this was replaced with a Grundfos UPS3.
The problem has persisted (it may even be worse), the pump noise is too loud even on setting 1 and the radiators are still not heating, one or 2 will get hot but the boiler cuts out quickly, it never runs for long.
I have tried
There is a manual (ball valve) bypass - 15mm from return to flow
There is an air separator
There is a shared feed and expansion pipe.
All that has changed since the heating worked well last winter is that a bathroom radiator was removed (pipes capped off) and a towel warmer moved a replaced with a taller one.
Any suggestions gratefully received
MC1
I have tried
- Balancing the radiators
- Draining and refilling the system
- Replacing the automatic air vent
- feeding mains water through the flow and return pipes - this seems to run well
MC1
