Here’s a problem for all you problem solvers!
I have central heating that’s a sealed system, a 2 way valve (?) with a timer upstairs in the airing cupboard which is also where the hot water tank and expansion cylinder are sited. Downstairs in the hall there’s a Drayton Digistat3 controller. The boiler’s in the kitchen.
We get hot water, so the boiler would, on that evidence alone, seem to be OK.
There was air in the downstairs 3x rad’s 4 days ago (which is when we noticed the fact that the house was cold so bled them then!) but the upstairs rads were hot.
After bleeding them I added more water to the system so it’s now at 1.8 Bar, up from 0.5 (presumably when I bled the rads, I let out too much water!).
Last night the upstairs rads were hot for a 30 minute period. Then nothing. The downstairs rads did not heat up at all.
I’ve played with the Digistat and checked all the settings. Likewise the timer in the airing cupboard is fine too, for all 7 days and the time / date both correlate.
When I ask for say, 23 degrees, we get the flame symbol on the Digistat, but the boiler does nothing.
I’ve spoken nicely to her, but she won’t work.
The system was here when I moved in 7yrs ago.
Any words of wisdom would be most appreciated.
