Hi all.
I'm hoping someone can help with advice with this particular problem.
I have an oil fired central heating system and a pressurised mains fed water supply.
Tonight, after being away for a few days, I pressed the water heater button on the programmer, and after about 20 seconds the mains tripped.
I then reset the electric, turned off the water heat button, and all was well. So I pressed zone 1 heating, and again, 20 secs later the electric tripped. I repeated for zone 2 (bedrooms) and the same thing.
After some research, I cheked the 3 motorised valves, and all seemed to be functioning ok, sounding smooth and starting the valve opening procedure for about 20 seconds before the power tripped.
That made me rule out the valves on the basis that one could be faulty and causing the problem, but its unlikely all three would be faulty and all at the same time.
So, out to the garage, where the oil fired burner boiler and pump are located. I was confident that I had narrowed the problem down to the pump. With the power off, I opened the centre screw, and turned the pump manually, all seemed smooth. I opened the power box at the side of the box expecting to see water in the compartment, but it was bone dry, clean and no sight or smell of any problem. I disconnected and reseated all cabling.
With all 3 zones on the kitchen based programmer all switched on, and the isolated switches to the pump and boiler switched off, I then turned the power to the pump on (it has its own switched supply beside the pump). The pump started normally and run without any difficulty.
So, the only switch left to turn on was the isolated supply to the burner. Switched it on, and it started its "warmup, pre burn " period. Then after 20 seconds, when usually the burner bursts into life, the whole lot stopped and the power went off again.
So I'm presuming its the burner unit thats causing the problem. Thats a pain, because the pump or valves, I can get my head round. The burner unit is big and complicated and scares me!!
I would really appreciate any advice as to what in the burner could be the problem, or most likely problem. Or if Im barking up the wrong tree. As I said though, by a process of elimination, I am fairly sure valves and pump are not to blame.
The other possibilty (doubtful) is a faulty programmer. I can't even get this opened, and its the discontinued model (Horstmann channelplusXL). The replacement model opens differently.
Please help!!!
Please help!!!
