central heating
Found the boiler :lol:
Not that it will do any good :lol:
Pump seems to be running are the pipes getting hot after the pump and how far can you follow the heat, :?: you need to find a motorised valve.
You say the hot water is ok at the cylinder :?:
would pay to check the header tank has water init
pipes hot after pump cant follow it far but the tank upstairs and the pipes around it aeem hot enough. a motorised valve would there def be one and would it be on a rad? header tanks full
it would suggest sludge or an air lock somewhere then
maybe worth flushing it out with a hose pipe.
Another thought nothings been turned off like a valve :?:
i have checked all rads they are all on and open the one in the front room i took of and flushed it out it was black that came out have put it back on. think i will stick a hosepipe on and drain the lot. if i open the valve to drian it the system should just fill back up its self should it or do i need to do something else to?
